question on virtual oscilloscope
come posso simulare un oscilloscopio sul mio PC
usando la scheda audio come DAQ (acquisizione dati))
How I can simulate an oscilloscope on my PC,
using the audio card like acquisition give to you?
(3,458 Views)
Vai su www.roboitalia.com c'è giusto il programmino che cerchi in libero
download!
non ti aspettare bande passanti a dismisura, il limite è hardware
Ciao
(3,458 Views)
giacomo,
Try using these VIs (LabVIEW Sound Card VIs for LabVIEW 5.0) to build a general DAQ application for your sound card. Then, write the output of your acquisition to a chart or a graph to display your data. I would suggest looking at the normal DAQ examples for inspiration.
Randy Hoskin
http://www.ni.com/ask
(3,458 Views)
