quick drop does not work for me
I can't get quick-drop to work.
I support software that needs to work in a multi-lingual environment, which means that some of the strings on the front panel of LabVIEW UI that I am writing need to be in Chinese.  So I followed the instructions here
http://digital.ni.com/public.nsf/allkb/91A1863834F4B1A0862575670067D15C
to allow other language characters to show up in LabVIEW.
Now when I press Ctl-Space in LabVIEW to bring up quick-drop, nothing happens in LV, but my language selector changes from EN to CN
How do I get quickdrop back???  (without removing my multi-lingual environment)
LabVIEW 2011 32bit, Win7 64bit system.
(5,063 Views)
You can go to tools/options and change the key combination that activates quickdrop to something else. It's in the "view" section of the tree.
LabVIEW 2012
(5,060 Views)
Try Ctrl-Shift-Space...I remember when we first added Quick Drop that there was something having to do with Ctrl-Space not being compatible with some Chinese configurations due to the Ctrl-Space shortcut already being used for something...so we have some condition having to do with Chinese settings where Quick Drop is launched with Ctrl-Shift-Space instead.
If that doesn't do it, I'm not sure what the problem could be...
(5,054 Views)
Ctl+Shift+Space doesn't work
I managed to dig into the language settings for windows on the language bar, and under Advanced key settings the Ctl+space was reserved for changing to chinese keyboard.  For some reason the "disable this key sequence" does not work (it kept defaulting back to enabling ctl+space), but I could change that key sequence to something obscure.  This let ctl+space work properly for quickdrop, which works better for me since it keeps my LV shortcuts the same as other systems.
(5,044 Views)
Thanks for posting the workaround you figured out.  I'm guessing that the Ctrl-Shift-Space thing is hard-coded for Chinese OSes...it sounds like you've got an English OS, but with Chinese locale settings, which I guess wouldn't trigger the switch.
Anyway, I'll keep this thread in mind in case I hear of the issue coming up again.
(5,042 Views)
I met the same problem (that's why i navigated to this page). Following  Steve Chandler's sugesstion, I found out the key combination for QD is ctrl+space in my Chinese OS (Win7 32bit). So I changed it to ctrl+shift+space. Problem solved.
(5,006 Views)
