quick hex string help
I know this should be very easy (or I assume it should be), but here is my question:
On the block diagram side, how would I convert the string so that it gets into the proper hex format, so when my string is 0907 in hex, my light will turn on. Basically, I cannot seem to format the string to a 0907 from the weird symbol that it is now. I know it has to do with how the string is stored, as a "normal string" vs "hex string", but could someone show me how to switch between the two on the block diagram side easily? (on the VI side its as simple as a right click, but I was having troubles finding it).
Thanks - and have a good weekend all.
(3,291 Views)
Accepted by topic author g_e_m_i_n_i
Your string is actually two characters \09 which is tab and \07.
Your case structure string should be "\09\07" which will get converted to "\t\07"
(3,286 Views)
I knew it would be easy. Thank you - and my your weekend be grand.
(3,282 Views)
