quick questions about visa/serial
Hi.
I'm using labview 6.0.
Under "Functions/ Instrument I/O / "
And then Serial submenu and VISA submenu.
In Serial submenu: VISA configure, VISA Read, VISA write, VISA Close.
In VISA submenu: VISA Read, VISA Write, VISA Advanced, VISA Clear,
VISA Read STB, VISA Assert trigger.
Question 2: Is there any difference between VISA Read/write between
the two menus? (For me it doesnt seem to be any difference
visually/practically)
Question 2: Why two menus? Or why isnt VISA configure and VISA Close
also in VISA submenu and VISA Clear in Serial submenu?
/J
(3,275 Views)
The functions are the same. The two menus are there for convenience I'm guessing. Someone developing a VISA serial application can tack down a single palette and have the most commonly used functions readily available. The same would be true of the regular VISA palette for GPIB/VXI development. The actual name of the VISA configure function you mention is VISA Configure Serial Port and it makes sense to put it on a higher level on the serial palette (it's also on a lower-level palette of VISA menu). When looking at function palette's, it's very helpful to have Show Context Help turned on. If you did that, you'd see that VISA Clear does a IEEE-488 device clear - not at all applicable to a serial device.
(3,275 Views)
Dennis Knutson wrote in message news:<506500000005000000EDC40000-1042324653000@exchange.ni.com>...
Ah, ok!
So VISA Clear can be used to clear a GPIB device for example?
While also GPIB Clear can be used.
I have another question:
I sometime need to empty com port buffer. Also i dont know the
transmit buffer of the device.
What is the proper way to empty all data everywhere?
VISA Flush I/O Buffer? what parameters?. VISA Read.. etc?
("VISA Read" works most of the time)
I know im not very specific here but I hope you can tell me something
useful anyway.
Thanks alot!
/ape
(3,275 Views)
I use VISA Flush I/O Buffer to clear a serial port. Doing a VISA Bytes at Serial Port and then a VISA Read with that numbr of bytes specified will work too but I'd rather use one function instead of two. Typically, all I need to do is flush the receive buffer because my programs are in charge of transmitting and I know that everthing in the transmit buffer has been sent so I just wire the VISA resource and let the mask input be the default.
(3,275 Views)
ok, thanks!
i'll try out some more later on.
(3,275 Views)
