quick start
this is the whole picture.
and i didn't understand one more thing - why after clear command
*clr
the buffer value still provided by the
read?
output?
Message 31 of 36
(2,028 Views)
*clr
read?
output?
Thank you for attaching your code. Unfortunately many of us, including me, do not yet have LabVIEW 2020 installed. If you could save for previous version that would be helpful - I'm using LabVIEW 2019.
Message 32 of 36
(2,013 Views)
Message 33 of 36
(2,001 Views)
Your code doesn't have the /n. Do you know the protocol for your instrument? Why the 111 for the read bytes? Why not use something larger and look for the termination character?
Message 34 of 36
(1,993 Views)
The 111 maybe enough, I guess.
The voltage various is about few microvolts, so that variable is double format enough. And the line end character is auto placed, and I guess that it's not need for this instruments model.
Message 35 of 36
(1,949 Views)
Why guess?
If you use \r\n (or any termination character) you can safely read 1000 character, and you'd know it's enough.
You'd have to explain that a bit more.
Message 36 of 36
(1,943 Views)
