You do not have to include all the dynamically called subVIs in your build. If you look at the shipping example called Plug In Example, the dynamically called VsubIs are in a subfolder called plugins. In this example, the paths to the subVIs are created based on what files are present and which have the correct type specifier. The high level VI can be built into an executable. The plugins folder could also be included with one or two subVIs but once installed, new subVIs can be distributed separately and just put into the folder. The only trick is to make sure that the path to the plugins folder is correctly obtained whether the VI is run in development mode or as an exe.
