"Advance Synchronization Techniques for Data Acqusition is not simple.
I want to use a 6534 DIO to drive my instrument and a synchronized 6502E to do AI from the instrument. The developer zone tutorial "Advanced Synchronization Techniques for Data Acquisition" suggests some of what is necessary to change from using AO as the master to using some other operation. After installing an RTSI cable, "Synchronized AI,AO,DI,DO,CTR.vi" runs as-is. Has anyone successfully converted the "Synchronized AI,AO,DI,DO,CTR.vi" or something similar to having some other master than AO? I want to use DO as master, and have moved the start vi's to the initialization cases except that for DO, have removed DI completely,and have tried to get DO to transmit REC1 on RTSI1 and AI and AO to clock o
n the RTSI1 signal. The modified VI runs to completion, but I get no input at AI.
Message 1 of 1
(2,403 Views)
