"Borders" of vi
What I must do, that when I run my .vi it will resize to size of my panel; must I add some borders, what, where?
_________________________
Rookie; LV 2011 on WIN 7
(2,582 Views)
You could try this.
"Fit VI window to Largest Dec is a member of the OpenG Application Control Tools (oglib_appcontrol) library."
Jim
(2,578 Views)
Hmm, thanks for reply, but inside labview there is nothing will do the same as this addon?
(2,573 Views)
Accepted by topic author hlod
One option for "Position" in the "Windows Run-time Position" page of VI properties is "maximized".
If you also scale all objects with the panel size, it will probably be close to what you want.
(2,562 Views)
