07-07-2005
03:41 AM
- last edited on
08-19-2026
02:50 PM
by
Content Cleaner
07-08-2005
02:37 AM
- last edited on
08-19-2026
02:50 PM
by
Content Cleaner
Hi HeVi,
I'm not sure that I completely understand what your issue is. Are you trying to launch a BAT-file after the installation of an application? In that case, I will recommend you to refer to the following KnowledgeBase:
Running a Batch File Automatically After an Installation to Access Installed Files
If the methods in this KB doesn't work, please let me know.
Have fun!
PS: I wish it was only 25 degrees celsius here - it's currently around the 40 degrees celsius in Austin...
Message Edited by Philip C. on 07-08-2005 02:42 AM
07-08-2005 04:12 AM
Yes, i'am try run BAT file after installation.
Attachment is my BAT file. It's quite simple("md C:\Temp\RfMeasResults, copy C:\Progra~1\RF_Mea~1\data\Data_Cable__05_05_2005.txt C:\Temp\RfMeasResults") only a couble command,
but nothing happens, it's not greating folder and not do nothing, not even error ?
I think I dont need any arguments be cause i just try run BAT file. so KB article looks like it's not help me in this case. And i'v been trying to give hole path name to executable, but no......
Any more ideas ?
-HeVi-
07-10-2005 10:57 PM
08-01-2005 04:36 AM
