I have run into the broken-wire error "You have connected two clusters that mismatch." This is a control that is leading into a sub-vi. The kicker is that both the upper-level vi and the sub-vi are referencing the same type definition for this cluster. Also, when I right-click on the sub-vi's terminal and select "create constant," that constant also is mismatched with the sub-vi cluster.
This problem developed when I copied all of the files (project, vi, all its sub-vis, type definitions) into a new folder. I use LabVIEW 8.2 under Windows XP.
Any insight into this strange behavior would be much appreciated! thanks!
