"Disabled" functionality of property node in global variable
I have a "Ring "global variable and  I am requried to disable it from a different sub vi. I am wondering how I can get the "disabled" functionality of a property node, in the global variable. is there a way ?
(2,980 Views)
"Disabled" is not allowed on global variables.  It makes sense if you realy think about it.
(2,974 Views)
Global Variables are already a "different" vi.
I don't know what you mean by disabling a global variable.  A global variable is a means to transfer data between VI's.  It is not a user interface element.
Do you mean that you have a Ring control in one VI and you want to disable that Ring control in a different VI?  If so, you can pass a reference of that ring control from one VI to the other and use the Disabled property node acting on that reference.
(2,971 Views)
Hi RavenFan,
Yes I do need to disable the ring control from the different subvi, I will try using reference.
(2,968 Views)
