"Enter" key on string control: dev environment is different from executable
I have a multi-line string control for entering a list of "stuff". When running the VI in the development environment (actually running it, not in edit mode), pressing Enter will halt text entry. To get a new line, you have to press Ctrl+Enter.
When this exact same VI is built as an executable, Enter will add a newline- not halt entry.
The control isn't set to Limit to Single Line.
Is there a way to make the two execution modes the same? I don't like surprises that only show up in a built executable.
(3,770 Views)
Hi Bert, is there any chance you are using 2 different keyboards when testing? For keyboards with 2 enter keys, the one above right-shift can act as a return key, giving a line feed. While the one at the bottom right of the numeric pad is used to confirm and end editing mode.
(3,749 Views)
Nope, same everything. I'm sitting here in the dev environment, using/debugging/modifying the code, and when I build it then run it (right click the build spec -> Run), the Enter key behavior changes.
It's not a huge deal but it would be nice to know. I would have guessed it's a setting in my editor environment somewhere, but I can't find it.
(3,738 Views)
Accepted by topic author BertMcMahan
The only item I'm aware of is under Tools-->Options-->Environment.  There's a checkbox available for "End text entry with Enter key".   I just now checked the LabVIEW.ini file.  Checking that box seems to map to a boolean key "returnKeyAction=True".  Unchecking the box seems to remove the key.  I don't honestly know whether manually setting that key in the .ini for your executable would let you choose the executable's behavior.
-Kevin P
(3,709 Views)
Edit: Kevin beat me to it!
How about this checkbox?
(3,706 Views)
Thanks Kevin, that did it. I checked my Options menu but somehow didn't see it. Maybe I need more coffee 🙂
(3,700 Views)
Or if you want to edit the executable behavior, you put this in your application's ini file:
(3,666 Views)
