Hello wewe,
At first glance it looks like your memory error may have something to do with your for loop that it initializing elt[i] = 0. When you define that struct, you set elt as a single element array. In the for loop, you are trying to access 500 elements of that array. You are indexing out of that array and probably setting all the memory after it to 0.
Hope this helps. If not, let me know, and I�d be happy to look further into it.
Have a nice day!
Robert M
Robert Mortensen
Software Engineer
