"File not found" when starting LabVIEW
When starting LabVIEW I get the information from windows: "File not found" even through LabVIEW is starting. Is there a way to avoid this (IE change program response timeout times in windows?)
Message 1 of 9
(4,736 Views)
hey
Are you launching LabVIEW by itself or through a VI? If its through a VI it could be a corrupted file! If its by itself then it would help if you gave some more info. What version of LabVIEW are you running and what OS are you using? Did you have any problems with the installation of LabVIEW?
Mohadjer
Message 2 of 9
(4,736 Views)
I see the problem too - running LabVIEW 7 on Windows XP, while starting by clicking on the vi icon. It normally only happens when the computer is very busy. That is, just after a reboot when all the services are being started. It's acting as if LV is expecting a response in say 5 seconds, the computer is busy so it doesn't get the response - puts up the "file not found" message, 2 seconds later it finds the file and displays it. If I close LabVIEW and try it again, it works fine - because the computer isn't busy any more. So the question is - where is the timeout value being set?
Les Hammer
Message 3 of 9
(4,736 Views)
Hi Les,
You are right. I do get the same message. I simply start LV and then use the File > Open and select the file to open it.
It's a bit annoying, but doesn't prevent from opening the file somehow.. ;o)
JLV
Message 4 of 9
(4,736 Views)
I think this is a Windows shell "feature". I see the same message
sometimes under W2K when opening Word documents which are locate
d on the
network. Sometimes Word aborts after a while and sometimes it still
opens the file after the error dialog has been dismissed.
Rolf K
Message 5 of 9
(4,736 Views)
hello, i would ask about why a ni zone example code problem. i try to run on LabVIEW and it says file not found...(as attached by picture)
the link on the ni zone is: http://zone.ni.com/devzone/cda/tut/p/id/6037#software
thanks.
zull azym
research assistant
RF department,
UTHM, malaysia
Message 6 of 9
(4,440 Views)
sorry, this the program that i take from this link,
http://zone.ni.com/devzone/cda/epd/p/id/5146
Message 7 of 9
(4,437 Views)
You should be starting a new thread, rather than adding a message to a 3-year old thread, as many may not see the message. All I can say is that I was able to open the VI. Try copying it to your local drive. It seems, based on the screenshot you provided, you have the file on a network drive so you may be running into the Windows shell timeout "feature" mentioned in the last message from 3 years ago, as well as more recently in other posts.
Message 8 of 9
(4,405 Views)
Continued here.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 9 of 9
(4,375 Views)
