"Formula" field in arithmetic and comparison appears blank on control panel.
When using the formula function in arithmetic and comparison, it appears to be blank when place on to the control panel. Is anyone aware of this problem and have a solution? I am using OS Windows XP and Labview ver8.5.
(3,154 Views)
Where is the Formula Function present in the Arithmetic and Comparison? Smiley Happy
What do you mean by the Control Panel - of Windows or LabVIEW's Block Diagram... ?! Smiley Surprised
Or, do you mean the Formula Node? Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
(3,151 Views)
See the attached picif you meant this?
(3,150 Views)
Sorry, I mean block diagram. I have attached an image to illustrate.
(3,146 Views)
For me, it gets placed correctly. Smiley Happy
I dont know what could be the problem. Smiley Indifferent
(3,128 Views)
Hi there,
This is a known bug in LV Base edition. Did you upgrade from an evaluation edition by any chance? You need to remove the existing formula VI from the pallette set and then pass in the correct path. See the instructions in the link below and then navigate to the path below and add it to the pallette. this should to the trick, any problems, let me know
it seems that the old working libraries associated with this instance still ship with LabVIEW 8.5, so they can use the following workaround:
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\express\express arith-compare\FormulaBlock.llb\Ex_Inst_Formula
In order to permanently add this to the Functions Palette check out this link LabVIEW Help Topic: Editing a Palette Set.
Rob L
NI Applications Engineer
UK & Ireland
It only takes a click to rate this message 😉
(3,079 Views)
