"Hide Last Item When Running" property
Its wrong for all except System. Classic, Modern, Silver, Fuse tested in LV24. See attached VI.
Certified LabVIEW Architect
Message 11 of 14
(363 Views)
Same behaviour in 2019! Combobox opens downward, Text rings upwards!
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 14
(345 Views)
FYI
The DMC Ring Menu control works as expected, list below control. The DMC Ring Selector control, does not work as expected.
However, there is a private property that can provide a fix.
After setting this property, it drops below. FYI, I don't know what needs to be set in the ini file to get this property.
EDIT: The snippet below "fixes" the other VI
Message 13 of 14
(333 Views)
Combo Box is different from Enum and Ring.
It's menu is part of the control.  It shows up on the Parts Window.  You can define the height of the menu.
For Enum and Ring, their menu are not on the Parts Window.
George Zou
Message 14 of 14
(320 Views)
