"How do I write data to PC RAM Memory from LabVIEW 7.0"
Hi Felix,
just read this: "I can not use Data Sockets because it dramatically slow down the data acquisition process"
... forget the ram-drive!
... shared RM would be (extremely) fast - though I expect you've already considered it...
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
Message 11 of 23
(2,249 Views)
hi there
you can increase datatransfer with datasocket when sending less items with more data. the vis attached send and receive a SGL[10000] array as a single string over dstp with less than 10 ms. the rate with tcp is quite the same.
(LV 7.1, WinXP SP2, Intel Mobile P4, 2.20 GHz, 1 GB RAM)
maybe you can optimize the number and the size of arrays.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 12 of 23
(2,229 Views)
Here's another idea felix,
How about you create a functional global variable.
Define all of it's inputs and outputs (we're talking set/get/reset etc)
The compile this into a dll.  Save that to your harddrive and use the exe's to access the dll to set/get the array values.
This way the values are stored in one memory space (associated with the dll)
Give that a go?
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
Message 13 of 23
(2,218 Views)
I don't know if you are still istening but you wrote:
"I'd like to make this data available to other LabVIEW application programs by writing it to the PC RAM Memory."
A number of the previous posts have given you the answer already but I will repeat it.
Use a Functional Global.
A properly coded functional global will maintain your data in a single buffer (the shift register).
With the appropriate functions the global can make all of your data available to any of the other LV applications.
THe global can be invoked dynamically from the "other" LV apps in similar fashion to gain access to the data that is "shared" by way of the functional global.
One more thought.
Queues are even faster than the LV2 if;
You know that data will always start at one place and end at another (que one place deque in another) but will require more coding to share between LV apps.
Ben
Message 14 of 23
(2,209 Views)
Dennis:
Thank you and the other guys for your suggestions. Tha new "Share Variables" in LabVIEW just drag my attention.
Do you know if this share variables work accross different LabVIEW Stand alone application programs (executables) ?
If Share Variables are used just internally on the same LabVIEW program, What would be the difference between them and Shift Registers.
Thanks a alot for your support.
Kind regards
Felix
Message 15 of 23
(2,195 Views)
Unclebump:
Thanks a lot for the link. I'll try it.
Regards
Felix
Message 16 of 23
(2,192 Views)
Tbd:
Thank you for your replay. I'll study the Ram-Disk suggestion you gave me.
Unfortnunately the customer does not allow me to write to the Reflective Memory because this data as you know will be sent as well to the other Reflective memory nodes on the Ref. Memory Network. My application should only read data from the Ref. Memory according to the project specifications.
Kind Regards
Felix
Message 17 of 23
(2,189 Views)
TO ALL LABVIEW GURUS:
A Big Thank you to all of you for your grate ideas. I' have been using LabVIEW just for few year but I din't know were so many LabVIEW enthusiastic out there
Thanks a lot for your support
Felix
Message 18 of 23
(2,182 Views)
Hey Felix.
I'm gonna hold my head up now and tell you that I was actually wrong about the functional global variable dll.
It works fine when you are in the development, however when the exe's are compiled they don't seem to work. (I assume that they open the two dll's in seperate memory spaces.)
Sorry about that.
I'm still working on it though.
AdamB
Message 19 of 23
(2,164 Views)
Adam,
Intriguing and attractive idea though.  Please post back if you find a workaround -- could there be a default DLL-build option (re-entrancy, thread-safeness, etc?) to uncheck?  I could imagine wanting to do this myself one day...
-Kevin P.
Message Edited by Kevin Price on 07-27-2006 11:22 AM
Message 20 of 23
(2,135 Views)
