"Is Value Changed.vim" and NaN
I know that NaN never equals anything (even itself).  So I'm unsurprised that if you feed "Is Value Changed.vim" an NaN, it will always return True.  I think I'm okay with that.
I just wanted to float this comment out to see if anyone else felt differently (or perhaps was unaware of this).  Does anybody think a clarification be included in the help documentation for "Is Value Changed.vim"?
(2,684 Views)
NaN is not a number, but it is a "value".  Is Value Changed is usually used to see if following code needs to be rerun because the result will be different due to a change in the value.  Is Value Changed is not about numbers at all, so I would say that NaN should not count as "changed" from NaN.
(2,651 Views)
What we would rather have is the LabVIEW equivalent of the "is()" function in Javascript:
https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Object/is
(2,599 Views)
