"LabVIEW FPGA: The compilation failed due to timing violations, but there is no path information because the timing violations are not of type PERIOD
After removing the clock from project exploer, should we reinstall it again? I guess the porject needs a leat one colock.
Message 21 of 27
(1,516 Views)
Hello Pidename,
I would recommend adding at least one clock to your FPGA target. You can do so by right clicking on your FPGA target and navigating to New=>Base FPGA Clock.
j_bou
Message 22 of 27
(1,470 Views)
Thanks J_bou, you are right because it cannot work without at least one clock.  The problem here is that my FPGA is set to run at 40 Mhz but for me to meet time requirement a need 15 Mhz. I can compile with 15 Mhz but when running it crashes without any output.
Message 23 of 27
(1,444 Views)
Hey Pidename,
Can you give me a little more infromation on the crash? Does it give you an error at all? It may be helpful if you can attach a screenshot of your code.
Ty Prather
Technical Marketing Specialist
Message 24 of 27
(1,382 Views)
Hello guys,
I'm getting the same error here. Some info:
LabVIEW 2012
Target: FPGA Target (RIO0, cRIO-9082)
Compilation Tool: Xilinx 13.4
I have tried both with the local compiler and the Cloud compiler service. It's odd that sometime I am able to compile (although it was taking much longer than normal (~2h), but now it goes on to ~1h30 a gives the said error: "The compilation failed due to timing violations, but there is no path information because the timing violations are not of type PERIOD."
Is there any info from Xilinx log that you would like to see, so that it would help?
Thank you in advance,
Message 25 of 27
(1,083 Views)
People on this forum post seem to have a similar issue and provided a few solutions.
https://forums.ni.com/t5/LabVIEW/quot-LabVIEW-FPGA-The-compilation-failed-due-to-timing/td-p/2012448...
Message 26 of 27
(1,061 Views)
Thank you Brian.
I assumed it was implicit, I had already tried those. None worked, unfortunately.
BR,
Message 27 of 27
(1,054 Views)
