"Languages:Current Language" not supported in this version of labview
    I am trying to change the lables on the Front Panel of my vi, dependant on what Language version of the LabVIEW Runtime enviroment has been installed.
In order to check what language I am currently using, I tryed the Property Node class "VI" type "Languages:Current Language". At runtime I was told that LabVIEW does not support this...
Is this because I am using LabVIEW Base, or am I missing somthing?
Cheers, Alec
(3,596 Views)
I guess you should use Application.Language instead of VI.Languages. Then you will receive the appropriate string.
Values include en, de, fr, ja, ko, and zh-cn.
Andrey.
(3,589 Views)
Great thinking. Only thing it, my first translation language is Dutch:smileysad:
(3,567 Views)
Unfortunately you will be not able to get Dutch from RunTime, because no Run-Time for this language present (as far as I know)
You can get language ID from OS:
GetSystemDefaultLangID Function
Language Identifier Constants and Strings
Andrey.
(3,564 Views)
Yes, that would do the trick. How would I integrate that command with labview?
Cheers, Alec
(3,561 Views)
Accepted by topic author alecjcook
Cheers, Alec
Call function from Kernel32.dll:
Take a note, that LabVIEW is non-Unicode, therefore you may get langugae ID, which was set for non-Unicode applications (check advanced settings in control panel)
Andrey.
(3,547 Views)
