"Launch Actor.vi" breaks with changes to Actor Core
I moved from LV2010 to LV2012 recently, and started modifying the Actor Framework template as per my application need. Here is the sequence of changes:
1) Create Independent Actors (while creating template)
2) Add extra actors, and assign proper inheritance
3) Open the Application Launcher Actor VI (One which starts the entire app layers and establishes connection between them)
At step 3, I modify the code to Launch several other actors and enqueue the messages. Everything works perfect, till a point that the Launch Actor.vi become broken (Shows static VI reference error) randomly.
Is there something I am doing wrong here?
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
(2,546 Views)
Reply given in this other cross-post thread:
https://decibel.ni.com/content/message/58846#58846
(2,445 Views)
