"Library.lvlib on Main Application Instance" Window Title, is this Lib still associated with previous project?
Hey folks,
Hopefully this is a quick and easy one-  I have a device that I already have a driver for which was placed into a lvlib along with the subvi's inside the driver (etc etc).  This lvlib was put together while I was working on a past project which I think was called "Main Application".
I'm new to lvlibs I guess, I just want to know if there is some sort of association between this lib and the old project I had, because after saving as, in a new location, opening up the lvlib shows the lib windows that says "Library.lvlib on Main Application Instance"...
Can anyone confirm that this is normal?  Does this title show up on all lvlibs regardless of where it's used?
thanks!
-pat
(2,338 Views)
Sounds good to me, does it work?
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(2,313 Views)
(sry about multiple username issue I have going, I'm the original poster)
I haven't had a chance to test it yet, I'm still working on the project that it's going to be implemented in... Talking to a few other people at work I think it's normal.
Thx
-pat
(2,308 Views)
