"Mean PtByPt.vi" not averaging data
I'm using in the "Mean PtByPt.vi" found in the standard "Probability & Statistics.llb", and it doesn't seem to be averaging.  It did last week.  Not it's not.
The attached image "Mean PtByPt Usage.PNG" shows how I'm using it.  It's in a while loop running at 100ms.  I also got the attached message (not in library.png).
Anybody else have this problem?
(3,836 Views)
Check this.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,782 Views)
