"Multiple Selection Dialog Box" VI Question
I've downloaded the "Multiple Selection Dialog Box" program and it works great, except when I add *.txt to the 'Files of type' array and then save it. I close the program and then reload it again and the change I made is not present...what am I missing?
tks
(2,610 Views)
Right-click on the 'Files of Type' array and select 'Data Operations,' and then select 'Make Current Value default.' Save the VI.
You'll now not lose this on reopening the VI.
Khalid
(2,610 Views)
Thank You....that worked!
Terry
(2,610 Views)
