"NI-DAQmx data"
Hi guys,
It seems that something in my NI MAX has changed overnight and I cannot see the tasks and channels that I create (or import) under: My System -> Data Neighborhood. when I create a task, I can go through the normal steps, but once I've saved it, it's gone and I cannot edit it or verify that it is even there.
I have imported configurations and run the programs and they work, so the tasks are there. To make sure, I then tried to export the configuration and saw that the tasks and channels were there under: My System -> NI-DAQmx data, which is a place that I cannot get to when in normal MAX (ie not in export wizard).
How do I get the tasks and channels to appear under data neighborhood as they are supposed to?
(2,560 Views)
OK,
I used the "Reset Configuration Data" tool under Tools and imported everything again and it works.
Totally weird that it had this speed-wobble!
(2,550 Views)
