"No block Diagram" VI conversion issue between 6.0 and 6.1
I'm trying to use a VI that was made in Labview 6.0. However, it apparently doesn't have a block diagram included. I checked the VI our in Labview 6.0 and it works fine. However, in Labview 6.1, I get an error trying to open the VI.
Is there a way to use VI's that don't have a block diagram from Labview 6.0 or do I have to recreate the VI in Labview 6.1?
I've attached a library file that contains two VI's that were both created in Labview 6.0. They both have no block diagrams
Any help will will be appreciated.
Taz.
(2,536 Views)
There is absolutely no way to convert a VI without a diagram to a different version. When the VI is recompiled to a new version, the source code is required. The diagram is the source code so you're goting to have to recreate it or find the original VI with diagram. As a rule, before I started using a version control system, I never saved VIs without diagrams because it's way too easy to overwrite the original.
(2,536 Views)
