"No listeners on the GPIB."
I'm getting the following error when I try to run GPIB on Labview:
"Error 2 occured at GPIB write in (filename).vi"
Possible reason(s):
LABVIEW: Memory is full.
NI-488: No Listeners on the GPIB.
This error tends to occur when an improper address string is written to the device. For example, if the device is 15 but the Labview address string is 28, this error will occur. However, I have already checked for that, and the address string is valid.
Furthermore, this is not specific for a particular device.  I have tried writing to other devices using Labview and I get the same error!  Therefore, I'm inclined to believe that the problem lies with the computer.
Message 1 of 11
(14,922 Views)
What does MAX show, and what kind of GPIB controller do you have?
Message 2 of 11
(14,911 Views)
Can you post any of your code?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 3 of 11
(14,902 Views)
The GPIB controller is a PCI card, with NI-488.2 for the software.
Here's what MAX shows for a sample program.
My System
Operating SystemMicrosoft Windows XP Professional Service Pack 2 (5.01.2600)
ProcessorPentium / x86 Family 6 Model 8 Stepping 6 / GenuineIntel / 930 MHz
Memory255 MB of RAM
Disk SpaceC:\ 22.6 GB of 29.2 GB free
D:\ 24.3 GB of 26.5 GB free
Back to top
GPIB0 (PCI-GPIB)
Interface Information
GPIB Hardware Model : PCI-GPIB
Serial Number : 13F04C2
General Settings
Primary Address : 0
Secondary Address : None
System Controller : Yes
I/O Timeout : 13 (10 sec)
Autopolling : Yes
Termination Settings
Send EOI at End of Write : Yes
Terminate Read on EOS : No
EOS Byte : 0
8-bit EOS Compare : 7-bit
Set EOI with EOS on Write : No
Advanced Settings
HS488 Cable Length : 0 (Disabled)
Parallel Poll Duration : 0 (2 usec)
Assert REN when SC : No
Bus Timing : 2 (500 nsec)
Message 4 of 11
(14,885 Views)
I meant what does MAX show in terms of the instruments on the bus?
The one thing I don't understand is that you're explicitly using GPIB Write as opposed to VISA.  Any reason why? New code should be using VISA instead of the GPIB functions.
Message 5 of 11
(14,882 Views)
VISA would probably work better.  As of right now though, GPIB cables are what I have to work with in the lab.
Now, in the "Advanced System Information" section of the MAX report, for GPIB, the bus type is 'pci', the bus number is 2, and the socket number is d (or 13 in hex).
What specifically are you looking for in terms of other instruments on the bus?  Do you mean other instruments on the bus which are not GPIB instruments?
Message 6 of 11
(14,872 Views)
Say what?
I think you don't understand the relationship between VISA and GPIB. VISA is an API that works with GPIB, RS-232, Ethernet, PCI, PXI, USB and has been the standard for GPIB communication for a long time. You really don't have any reason to use the low level GPIB functions.
At some point, you should have right clicked on the controller and done a scan for instruments. You instrument should then be listed.
Message Edited by Dennis Knutson on 07-28-2009 11:38 AM
Message 7 of 11
(14,867 Views)
Ok, so now I'm trying to use the VISA functions for GPIB, and I get the following error at "VISA Open":
Error -1073807202 occurred at VISA Open in GPIB check.vi
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
The resource name is "GPIB0::18::INSTR" because the board index is 0 and the instrument address is 18.
Message 8 of 11
(14,843 Views)
Did you try a search? See here: VISA Error -1073807202 (0xBFFF009E).
You still haven't told us what MAX shows for the list of instruments on the GPIB bus.
Message 9 of 11
(14,840 Views)
Without the list, it's kind of difficult to figure out what the problem is, but I'm betting that there is no instrument at address 18 connected to your PC.  This means that either 1) The GPIB cable is not connected or 2) The instrument is at a different address.
Slight possibilities:
  There are two instruments at address 18
  One of the other instruments thinks it is the system controller
In any case, (after you get the list from MAX if possible), you should go to each instrument's front panel and find out what address it thinks it is and whether it thinks it's the system controller or not.
-Matt Bradley
Message 10 of 11
(14,832 Views)
