"Not enough memory to complete this operation" & "Memory is full"problems with Labview 7.1
@Sam_Sharp wrote:
Instead of Build Array, you should pre-initialise your array instead with the required number of elements.
Yes just do remember that after you pre-initialize to use the replace array and not the build array again.  It may sound strange but I've seen beginner developers who heard using build array could be bad and to initialize the array to the size they needed.  They were not told to replace the elements within this new array and instead just kept on building an array in addition to the initialize array.
Message 11 of 22
(1,717 Views)
85Mb might sound big, but it's far from full memory so it shouldn't really be a problem, it's rather the handling of data and operations on the text causing copies. There's no In Place element in 7.1, right?
So, you're reading a text file in line more, and reading all at once? Then you should have an array of lines and should be able to work on each and use replace array element. If you read it all as a massive chunk and change the text i assume LV will copy the full modifies text to a new memory location quickly causing problems.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 22
(1,689 Views)
SO: 🙂
- I have replaced my array subset with index array where possible ==> not important changement in my program
- i have replaced a build array in a for loop with one initialize array and insert into array ==> my program become worse than before :'( Before this changement i couldn't open 80Mb file but i could open/read/handle 40Mb file. Now LV put me in wait also for 15Mb files 😞 it don't returns me errors but i have to close LV with ctrl+alt+del
Why? 🙂
finally i have to try with chunking tecnique 🙂
do you have a tutorial or guide that expalin me step by step in which way can i implement this procedure? 🙂 maybe with some exaplems that i can read with LV 7.1
Thanks again
Using LabVIEW 7.1
Message 13 of 22
(1,670 Views)
Hi gigi,
Yes, that's true. But no one will suggest to use InsertIntoArray! You should use ReplaceArraySubset on a pre-defined array...
Btw. do you mind to attach your VI or even a picture of the BD?
Message 14 of 22
(1,668 Views)
replaced insert into array with ReplaceArraySubset Smiley Embarassed
anyway i obtained not visible improvement 😞
i can't attach my VI sorry....property of the company where i work 😞
what means BD anyway? 😄
Using LabVIEW 7.1
Message 15 of 22
(1,659 Views)
Hi gigi,
BD is a shortcut for block diagram.
You're not able to create a small VI demonstrating the purpose of your big and company owned program?
You're not able to create and attach a small VI just showing the part of your program you're having problems with?
Message 16 of 22
(1,670 Views)
See attached picture (cant insert in IE)
/Y
Qestit Systems
Message 17 of 22
(1,649 Views)
Hi Yamaeda,
gigi decided to create a new thread to continue on this topic...
Message 18 of 22
(1,641 Views)
yeah....
i changed my thread to try to focalize the point to read in chunks 🙂
here the new link
http://forums.ni.com/t5/LabVIEW/Read-file-in-chunks/td-p/2628857
anyway i tried to put put line mode on and put 1000 on count....i hoped to receive 1000 lines but it didn't happen...i read only the first row
in attachment the image
Using LabVIEW 7.1
Message 19 of 22
(1,635 Views)
That sounds very strange, it's not just hidden outside the indicator? Try resizing it.
/Y
Qestit Systems
Message 20 of 22
(1,592 Views)
