"Not enough memory to complete this operation" message
Hi Matt,
Yes, you are doing it right:
  • Open “RWM_LAB font panel dummy DAQ.vi”
  • Select first 5 channels
  • Start capture  (about 5 seconds)
  • Stop capture
  • Start capture again – error occurs immediately.
(and reappears each subsequent time one hits the Start Capture or Quit Program buttons).
This is with 64-bit Windows 7 Enterprise, running Labview 2013 SP1  (13.0.1f2, 64-bit).    I have two computers like this and they both give the message.
If I try it on an old laptop (Windows Vista, Labview 2013 SP1 (13.0.1, 32 bit)) I don't get the message.  Interestingly, when I quit Labview on this machine it prompts me to save all the VIs, with a  message for each one something like "VI has been reconfigured for new system.  VI has been recompiled".  Maybe the recompilation fixes the problem or maybe it is a fault with the 64-bit implementation?
Roger
Message 11 of 17
(1,450 Views)
Hi Roger,
I'll see about installing 64-bit LabVIEW and testing this. Can I ask why you are using 64-bit however? Even on a 64-bit machine, we would recommend using 32-bit LabVIEW, as this is much better for compatibility, and much easier to support. If you don't have any need for the 64-bit LabVIEW features I would highly recommend switching those PCs to 32-bit.
Kind regards,
Matt H
National Instruments UK
Message 12 of 17
(1,441 Views)
Hi Matt
I just installed the university-licensed version from our School of Engineering intranet - only has the 64 bit version.
I don't think NI has told them that the 32-bit version is more reliable.
Roger
Message 13 of 17
(1,430 Views)
@roger1922 wrote:
Hi Matt
Roger
Well, not more reliable - just more compatible.  Remember how hard it used to be to find drivers and stuff for 64-bit Windows?  Well, there's much more support in the NI world for LV 32-bit than LV 64-bit.
BTW - if you have a copy of LabVIEW 32-bit, you can install it alongside the 64-bit version using the same license.
Bill
CLD
(Mid-Level minion.)
Message 14 of 17
(1,420 Views)
@billko wrote:
@roger1922 wrote:
Hi Matt
Roger
Message 15 of 17
(1,395 Views)
 Thanks Bill, I have now got both 32 and 64-bit installed.
The bug occurs in the 64-bit version but not the 32-bit.   It's not a question of drivers - Labview is just generating random numbers, not communicating with any kind of hardware.  So I would say the 32-bit actually is "more reliable".
Roger
Message 16 of 17
(1,386 Views)
Well, I'm glad you found a workaround for it.  (I call it a "workaround" because you shouldn't really have to install a different version of LabVIEW than the w=one you wanted to use.)  🙂
Bill
CLD
(Mid-Level minion.)
Message 17 of 17
(1,364 Views)
