10-22-2009 02:08 AM
I get this message when trying to check for parallelizable loops:
Btw. this message is shown when menu item is selected from a vi belonging to an open project...
When I select the same menu entry from a project's menu I get:
What's wrong here? I'm using LV2009f2 (including latest patch), but had the problem already before applying the patch.
10-22-2009 04:05 AM
Hey,
I did a little search on that in our databases, without results. Seems that there is something wrong with your LabVIEW Installation.
Christian
10-22-2009 08:44 AM
Hello Christian,
thanks for your investigation.
I made one more test:
When searching for parallelizable loops on the very same vi, but opened as "stand-alone" without a project open, the tool works and says:
So it seems to be a problem of the project file?
Re-installing LV2009 isn't really an option at the moment ![]()
10-22-2009 09:36 AM
But you can at least repair LV ![]()
Christian
10-22-2009 09:48 AM
10-22-2009 09:50 AM
10-22-2009 10:33 AM
@Jarrod: For sure I reproduced it. Well it took me a lot of work and time to navigate to Tools>Profile>Find Parallelizable Loops in a Project, or without Project, or in a Project with differnt targets....
@Gerd: Are you using a english or localized version of LV, can you post your Project or at least the VI.
Christian
10-23-2009 01:46 AM
Hi Christian,
thanks for your effort!
I'm using an English version and I can't attach the whole project...
I just made one more test and added the vi in question into a new, fresh, clean & empty project. After selecting "find parallelizable loops" LabView took a while (maybe because project wasn't saved before), but showed the same successful result ("Loops may or may not...").
So I think the problem is with the project file itself - which consists (at the moment) of ~20 autopopulating folders.
Do you have access to my private email address in the user profile to discuss this more detailed?
10-23-2009 04:06 AM
I have no direct access to your private email, but I will ask to get it and write you an email then.
Christian
