"Pre-Run" Code Execution
Another big advantage of the technique above that I forgot to mention is when the functional global outputs data. For instance, let's assume the Execute case of the functional global outputs the current value of the ComboBox. That means the functional global has a string output. But this string output won't make any sense if referenced from the Read case, since it only involves initialization.
The technique above allows you to only output data from a functional global only where it applies by ignoring it in the polymorphic instances where it doesn't apply.
Jarrod S.
Message 11 of 12
(560 Views)
Nice posts Jarrod. Smiley Happy
Learned a lot from comments re:connector-pane and execution-speed.
Cheers.
Message Edited by Dynamik on 04-12-2006 02:51 PM
When they give imbeciles handicap-parking, I won't have so far to walk!
Message 12 of 12
(545 Views)
