Lab Technician wrote:
> I am measuring temperature using the "5508TC adac" board on
> Windows2000.I have a "K-Type" Thermocouples, but I can't select the
> channels from the Measurement and Automation Explorer window using
> Labview 7.0 software.When I click on NI-DAQmx in Labview 7.0;I clicked
> on "Analog Input" then Temperature, Thermocuples then it says "no
> supported devices found".I even installed an updated version of NI-DAQ
> drivers, but I'm still facing the same problem. What do I need to
> resolve the problem?
I'm sorry but Measurement & Automation Explorer is a National
Instruments software and knows only about National Instruments hardware.
The same applies to the DAQmx functions.
You will have to ask the manufacturer of your board for a config
uration
utility for your hardware and also some LabVIEW drivers.
Rolf Kalbermatter
Rolf Kalbermatter
My Blog
