"Save measurement to file"-VI doesn't obey the "Use next avaible file name" setting
Hi ReBoot,
if it not work with an empty path you can connect a path constant like shown in the attached picture.
Mike
Message Edited by MikeS81 on 04-04-2008 02:13 PM
Message 11 of 16
(863 Views)
The path itself is not a problem. The problem is only that the VI doesn't take the next file name.
Message 12 of 16
(857 Views)
Hi ReBoot,
on my Windows system it works fine, could be that there are differences to Linux.
Mike
Message 13 of 16
(855 Views)
Hi ReBoot.
I managed to recreate the Problem You're seeing.
I tried to put a For loop with 10 iterations around the Example i posted and then run it. Suddenly the express VI only creates one file but with ten times the data.
It seems that the Express VI doesn't manage to finish writing the file before the next iteration.
So try wiring the Error out to the Outer While loop..... that should do the trick
/BCL
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
Message 14 of 16
(853 Views)
Hi ReBoot,
i think i got it. Set the "reset" or "zurücksetzen" input to true.
This should help you.
Mike
Message 15 of 16
(847 Views)
Hi again.
Tried something new.......Its not rocket science but it actually works......
I wired the filename output, back to the filename input.....and tadaa.......Its creates a whole lot of LVM files.... 😉
/BCL
But there's NOT
LabVIEW 2012-2017
Message 16 of 16
(843 Views)
