"Save vi seperate from code" at import
Hi. I have a lot of code in LabVIEW 2009. I would like to import it all to LabVIEW 2010, but I would like the "Save vi seperate from code" checkbox checked on all imported vi's (I would like it checked on all subsiquently created vi's too). Does anyone know how to do this?
Many thanks, Alec
(2,649 Views)
Can't you open the project in 2010 and then save as =>  a distribution?
kind regards,
Bjorn
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(2,647 Views)
HI, it's the "Seperate Compiled Code from Source Code" checkbox in the vi properties that I would like to set. "Save As" does not give me a "Distribution" option. and through the project view, compiling a "Source Distribution" does not give me the option to set this setting 😞
(2,636 Views)
Accepted by topic author alecjcook
LV 2010 does not allow doing this, but there are some VIs floating around which will do this at a specific point in time (you can also write one yourself fairly simply, as the property is exposed through VI server).
Another option is to open a new project and use auto-populating folders to add all the VIs in a hierarcy to that project. You should then be able to use the marking window to mark all of them.
___________________
Try to take over the world!
(2,621 Views)
