"Scan From String" - something I didn't know...
@DavidBoyd wrote:
The other comment I really wanted to make:  as a long-ago C programmer, I've always used LV's Scan From String and Format Into String nodes for their versatility and coherence with C stdlib's sscanf() and printf() and their ilk.  That entire subpalette of Number/String Conversion one-off nodes is a no-go zone for me (20+ years of LV programming). Give me error terminals, offset past match, and growable inputs/outputs!
I actually find myself using the Number/String Conversion palette more and more over the years.  This is pretty exclusive to when I only have 1 value.  But I would say that I abuse the Scan From String and Format Into String nodes.
Message 21 of 25
(885 Views)
They have one big advantage: the work on arrays.
Message 22 of 25
(864 Views)
Subtle correction:  "... most work on arrays" 😄
Message 23 of 25
(850 Views)
I totally missed the fact these nodes are polymorphic - for clusters, too! - and in both conversion directions.  Thanks, Wiebe!
Interestingly, the default value input (to be returned for a scan failure) doesn't adapt to the datatype, so you only get one common default.  But I suppose these nodes are really intended for bulk conversion of like elements anyway, so that's hardly a limitation.
I'll have to keep these nodes in mind next time I encounter a situation where bulk conversion is needed.
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
Message 24 of 25
(840 Views)
My most frequent use case is to display 2D numeric arrays in a table. One step! 😄
Message 25 of 25
(836 Views)
