"Should be simple" counter question
So I have a VI like the one below where I want to build multiple 100 element arrays. However, I want to start taking 100 points of data at different offsets. Once I have my 100 points in the first case structure, I want to reset my counter so in the first case structure I start taking data again. But then because of the offset, the other case structures haven't built their 100 point arrays yet so I want them to continue taking data for another 20, or 40 points respectively despite the counter being reset to 0. I am trying to avoid a bunch of parallel loops of a bunch of different counters since I will have more than 3 offsets so that's why I'm trying to do it this way. Any suggestions on how I can relate my counter to the different cases in a way that will allow me to do this?
Sorry that was a bit wordy let me know if anything is unclear.
Message 1 of 15
(4,202 Views)
This looks like a job for the Feedback Node.
Message 2 of 15
(4,172 Views)
People actually understand how those work? Smiley Tongue. I should have added, this is on FPGA...will feedback nodes still work? Also, how do i set the 20/40?
Message 3 of 15
(4,162 Views)
I have some vague recollection that these things were built with FPGA in mind.  Can't tell you myself, I don't do FPGA.
Message 4 of 15
(4,146 Views)
Sorry, editted my above post after your response so I'll post again, how do you add 20/40?
Message 5 of 15
(4,143 Views)
Right-Click the FN, and select Properties.  The delay is on the configuration page.  I have also reversed the direction.
Message 6 of 15
(4,140 Views)
Uh oh....so i just realized I can't set the delay programmatically (I don't think) and there are times it will need to be changed..NOW WHAT? May need to resort to shift registers somehow
Message 7 of 15
(4,131 Views)
If you are using the LabVIEW 2010 FPGA Module, there is a function on the High-Throughput Math»Basic Elements palette called Discrete Delay.  If you double-click, under Delay Settings you can specify a dynamic delay and a maximum value possible for the delay.  Then, you can programmatically change the delay for each node.
24404i83C32D718F41ACAB
Donovan
Message 8 of 15
(4,113 Views)
I don't see it in high throughput math but I do have an express VI called discrete delay in another palette. Same thing?
Message 9 of 15
(4,107 Views)
My all means use the FPGA VIs if you have them.  You could also do this, the Integer Quotient is negative until the offset is reached.
Message 10 of 15
(4,101 Views)
