"Simple" Text Based Expression Evaluator?
I am writing some control logic code in LabView and have a
somewhat interesting question. I would like to provide users with the
capability of entering a "simple" text expression, and the "evaluator"
would respond either with a numeric or boolean value. Examples would be:
a+b
a*ln(b)
a+b>c
An even better "evaluator" capability would be to provide a
BASIC-like block of code:
IF a+b > c
THEN d=1
ELSE d=2
ENDIF
Better still:
IF ((a + b < c) AND (a < 5))
THEN d=1
ELSE d=2
ENDIF
Some of the requirements are:
1) Variable number of input and output variables
2) Some method of checking for a valid expression
Any help would be appreciated in this manner.
Andy
Andy Steinbach
stei0113@tc.umn.edu
(3,838 Views)
On 8 Jul 2000 18:34:55 GMT, stei0113@garnet.tc.umn.edu (Andrew J
>a+b
>a*ln(b)
>a+b>c
I have written a basic infix expression evaluator, and I could send
you a copy via email if you wish. Keep in mind that while it does
support constants, variables, and all of the standard operators, it it
still quite rudimentary.
I have not worked on this VI since I have begun using the GMath
Evaluate Formula String VI. It is certainly more robust than mine -
although I have not q
uite figured out how to manage a set of
user-defined variables (transparent to the VI), but that is another
issue all together.
>IF a+b > c
> THEN d=1
> ELSE d=2
>ENDIF
> Better still:
> THEN d=1
> ELSE d=2
>ENDIF
I usually write my interpreters/compilers in a "real" language (i.e.
C/C++). 🙂
Reply via email if I can be of assistance.
Brett
(3,838 Views)
we'd exactly the same problem and found a very suitable solution by
implementing the TCL-Shell (http://dev.ajubasolutions.com/) along with an
interface DLL/LIB in LabVIEW. It's only little work to get TCL running. TCL
is a very powerful bytecompiling interpreter with many many features (using
Tk-Extension also with a very powerful graphical interface 😉 and it's free.
The DLL is a simple interface to read and write TCL variables also from
LabVIEW without using TCL-Interpreter calls.
Jens-Achim
> would respond e
> a+b
> a*ln(b)
> a+b>c
> IF a+b > c
> THEN d=1
> ELSE d=2
> ENDIF
> Better still:
> THEN d=1
> ELSE d=2
> ENDIF
> Thanks,
> Andy
> Andy Steinbach
> stei0113@tc.umn.edu
TECHNOGERMA Systems GmbH
Dipl.-Ing. Jens-Achim Kessel
Departement for Automation and Control
D-64291 Darmstadt, Roentgenstrasse 10a
phone: <++49> (6151) 99 58 7 - 74
fax: <++49> (6151) 99 58 7 - 62
e-mail: tgs.kessel@gmx.de
(3,838 Views)
I've read the answers in this thread, and I don't even think it's that
hard. I've done the same thing using LabVIEW code, and it's very easy.
If you have LV 5.1, look at the Mathematics->Formulas->Eval Formula
Node.VI in the diagram. This is similar to a formula node, except the
formula (as a string) is sent into the VI, parsed, and the answer comes
out. Basic if/then, boolean, logarithmic, and many other functions can
be used in the formula. I'll be more than happy to email you the VI so
you can look at it if you'd like.
Mark
In article <8k7s8f$pu4$1@laurel.tc.umn.edu>,
with the
be:
> a+b
> a*ln(b)
> a+b>c
> IF a+b > c
> THEN d=1
> ELSE d=2
> ENDIF
> Better still:
> THEN d=1
> ELSE d=2
> ENDIF
> Thanks,
> Andy
> Andy Steinbach
> stei0113@tc.umn.edu
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,838 Views)
Andy,
The CalcExpress is powerful interpreter of expressions for LabVIEW. You
can find more information and download evaluation version on
http://calcexpress.mypage.org/
and
http://www.e-notebooks.com/products/calcexpress/
For processing of conditional expressions there is free addon for
CalcExpress. For more information you can contact with me by private
email.
Konstantin Shifershtain.
snow@fivt.kgtu.runnet.ru
be:
> a+b
> a*ln(b)
> a+b>c
> IF a+b > c
> THEN d=1
> ELSE d=2
> ENDIF
> Better still:
> THEN d=1
> ELSE d=2
> ENDIF
> Thanks,
> Andy
> Andy Steinbach
> stei0113@tc.umn.edu
Before you buy.
(3,836 Views)
