"Small Font" in LabVIEW 2013/2012 Icon Editor
you may install goop tool,including Icon editor.
Message 11 of 21
(6,065 Views)
hi,ronke
I think perhaps the issue has no relationship with the icon editor what I choose, cause when I edit any text with "Small Font" on front panel, the font doesn't take any effect(the same as "Times New Roman Font"). Besides, I also use the legacy Icon editor by renaming the default "lv_icon.lvlibp" tool. the problem still exists.
Note:My LabVIEW Version is LabVIEW 2013-32bits English, and Computer OS is Window7-32bits Chinese Version. I also know that there is no problem when using Engish Window 7 OS.</p
Message 12 of 21
(6,048 Views)
Is this a free tool ?
Doug
"My only wish is that I am capable of learning each and every day until my last breath."
Message 13 of 21
(6,001 Views)
hi ronke,
Can you please provide a link.
Message 14 of 21
(5,744 Views)
Hi Xyl,
Have u fix this issue already? If you did, can u please tell me how to do!
TKS
Message 15 of 21
(5,740 Views)
Accepted by topic author xyl4804
Open "LabVIEW.ini" file and then Edit or Add followings.
After all, restart LabVIEW.
FontCodePageList=Small Fonts,1252
Good Luck!!
Message 16 of 21
(5,654 Views)
thank you very much,SOLVED!!!
Message 17 of 21
(5,533 Views)
hi,Open "LabVIEW.ini" file and then Edit or Add followings.
Message 18 of 21
(5,529 Views)
This is a problem that has plagued me all the time. It's been solved now. Thank you very very very
@MacgyverLee 已写:
Good Luck!!
Message 19 of 21
(5,188 Views)
Do you konw what's meaning of 1252? Thanks。
@MacgyverLee
@MacgyverLee
Message 20 of 21
(5,160 Views)
