"The LabVIEW project library does not sharre a common path to disk with the files the project library owns" msg
I thought this was a file the project library owns.  So what's up?
(3,451 Views)
App note: http://digital.ni.com/public.nsf/websearch/43B5686A6AE4DD118625714800797878?opendocument&Submitted&&... did not help.  If the .lvlib is included in the .exe what is the runtime path?  See attachment.  The only way I can get this to automatically deploy is by including the .lvlib file in the same folder as the app .exe on the RT target and set the deploy libraries path as such.
(3,421 Views)
I worked with RAMaston on the phone to resolve this issue. The solution was to ensure that the Application from under Build Specifications was selected when adding the source files for the installer and not selecting files from under the My Computer target.
When specifying the library path on the block diagram, the Default Data Directory constant can be used from the File Constants Subpalette to build the library path.
(3,404 Views)
It worked.  Thanks lion-o
(3,398 Views)
What if I have no application?  In other words I'm trying to build an installer ONLY to distribute an XControl?  I get this error and I don't know how to correct it.  Thanks in advance!
(3,127 Views)
Answered here
Ton
My LabVIEW Ideas
(3,111 Views)
