"The New file dialog could not be displayed.
I was messing around with scripting a project.  I aborted the VI while a new project reference was still open.  Now when I select "menu → File → New ..., I get this:
Do I have to do a full repair of LV to fix this?
(1,916 Views)
Some questions for Inquiring Minds (if we want to try to reproduce this, we better use cloned VMs ...) --
  • What Version of LabVIEW (edition and bitness)?
  • Can you be a bit more specific of the "steps leading to failure"?  A "reproducible failure" is easier to track down than a "random" one ...
Bob Schor
(1,873 Views)
It was version 19.0.1f3,  32-bit.
I was experimenting with some code that was to create a project.  The new project had been created, but not saved yet.
Of course reproducing the problem would require that I fix it first.
When it comes right down to it, I'm not 100% sure that this is when it broke.  It's possible that something broke it at an earlier time.
But regardless of what broke it, I still need to fix it.
(1,855 Views)
Nothing specific, but if memory serves, this should be launched using <LabVIEW>\resource\plugins\lv_new.vi
Maybe you modified something there?
___________________
Try to take over the world!
(1,811 Views)
Thank you.  With that information, I was able to determine that "UDCLogEveryFeatureUsage.vi" was broken because somehow "niceiplib.lvlib" lost track of it.  A simple edit of the library fix the problem.
(1,785 Views)
