Hello Kenos,
If you were working with plain text, it would be a simple matter to use the offset function of search string node. However, since Word documents have a HUGE amount of nonstandard characters for formatting (even RTF format is pretty scary in this regard), you will probably have to use the Search for Tokens, and explicitly define what you consider to be "text" as opposed to formatting symbols. This is "doable", but certainly not fun. Since formatted Word documents can only be read with an actual WORD application....are you sure you can't automate this better with a Word macro? It might be easier to call up WORD from within Labview than to actually do these word processing functions with Labview directly.
Just a thought
chutla
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
