"VI is not loadable" error.
Trying to help out, I run into a weird problem and I wonder if it is just me.
I was able to edit the posting.vi (a few posts up), but after saving the edit, I can no longer open it at all. I get the error as seen in the picture.
Believing it has to do with my lack of IMAQ, I went back to the original VI and tried to convert it to 7.1 so I can use my 7.1 student edition at home which includes IMAQ. However, I cannot downconvert from 8 to 7.1, I immediately get a very similar error.
Bug? Feature? User error? 🙂
Message Edited by altenbach on 04-20-2006 10:26 AM
(2,906 Views)
Hi Altenback,
You are not aloneSmiley Surprised
I experienced the same, identical message
Also I do not have IMAQ installed.
Regards
xseadog
(2,880 Views)
Hi guys,
I know it's been a while but I came across this post when I was researching the same issue for a customer.
If you are using a waveform chart in your application then that could be what's causing the issue. It's a known bug in 8 that's been fixed in 8.20. The suggested workaround is to save the VI without the graph, open it in 8.0 then rebuild the graph.
Hope this helps!
Sarah
Applications Engineer | National Instruments | UK & Ireland
(2,819 Views)
