"VI properties malfunction"
   In the VI properties I have a check next to Run when opened. However, when I select the VI from the project explorer it does NOT run. It opens in edit mode. Anyone know how to fix this problem? I am using Labview 8.0.
Many Thanks,
Charlie
Message Edited by ccurtis on 12-21-2005 04:15 PM
Everything is Free! Until you have to pay for it.
(2,436 Views)
This is probably by design.
Personally, I think the described behavior is much more desirable in an code development environment. 🙂
('don't know if you can change this bahavior).
(2,425 Views)
