"Variant to Data" VI returns an error when reading from Access.
Using the Database Connectivity Toolset, I can WRITE to an Access Database using DB Tools Insert Data.
When I attempt to READ from the same database, the DB Tools Select Data VI returns data of type variant.
I cannot convert this data into anything useful (although I can PROBE it - so it is there!)
The VI which OUGHT to work is, I think, "Variant to Data".
But this returns error 91. Incompatible variant data type.
Any ideas how to extract data from Access???
(2,843 Views)
See the "SixType Select.vi" under database tools examples library.
A Rafiq
(2,843 Views)
Thanks! The info in the "Sixtypes Select" ID showed me how to get the first item in the first row. I wanted the first item in the last row, so a condition sent to the DB Tools Select Data VI to sort the database in descending order of this first column
( ORDER BY TblMainRuns.MainRunID DESC )
works fine!
Problem solved. Thanks again.
(2,843 Views)
