"Why do I get a 'BLOCK INPUT ERROR' when I try to recall the state"
I'am trying to save /recall state and calibration for HP 8753 ES. I have the driver 8753x, from NI site and I'am usig its save/recall state module.
I can save a state, but I can not recall it. when I run recall the following message is on instrument: Caution: block input error".
(2,601 Views)
Given that you got the drivers off the NI site, I assume that they are probibly IVI? If so, you need to talk to NI they wrote them and there's no way to look at what's really happening (from within LV at least).
You might want to check to see if you can find some non-IVI drivers. When they don't work you can at least fix them.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,601 Views)
Quick follow up, I just checked and I have a set of non-IVI drivers for this instrument that I can send you. Don't know if they work but I'll send them to you if you like...
If these are the drivers you have already, which subVI is actually generating the error?
Mike...
LabVIEW Champion
(2,601 Views)
Hi I have exactly the same problem. Can you send me the driver that you have? I would like to try it. Thanks
(2,601 Views)
