"file already exists in the destination" during application build
I am trying to build an executable and have gotten the following error:
The file already exists in the destination.
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Sentech LV 82\Shared Library - Trigger SDK\StTrgApi.dll
WHen I start the build I go to "Build Executable" then click "Build"
The VI for the project I have open is the Startup VI and I do not list any Dynamic VIs or Support FIles.
I am using Labview 8.2
I installed a user library for a USB camera from Sentech wich I am using and it works fine in Labview 8.2
When I try to do the build I get the error shown above. The file it is referencing is there along with the .lvlib file.
I tried removing the file shown in the error message to see what would happen and I continue to get the same error even though the file is not there. I even restarted LV and still got the same error.
I am new to the application builder (v7 ?) and have not been able to find any good tutorials. Does anyone have any ideas on this error or a good place to learn more about app builder.
Keith
(2,821 Views)
Keith
Hi Keith,
you can check this Link out for a tutorial on app builder.
Denver
(2,791 Views)
