"filewatcher labview"
Hallo
Hat jemand von Euch bereits einen filewatcher (ein Programm das nachsieht ob ein anderes Programm Daten in ein file schreibt, und mir dann den zugriff auf diese Daten ermöglicht.)
Ich benötige ein sollches Programm dringend Version 7.1 bis 8.2 vorhanden.
Vielen Dank Werner
(3,003 Views)
Hi Werner,
in the file palette you find a function named 'File/Directory Info' (LV7.1). This will give you filesize and last modification date.
To read the file you can use 'Read characters from file' (or any other file read function)! But be aware of problems when the other application prevents file access...
Try to use English, you will get much more answers...
Message Edited by GerdW on 04-19-2007 11:05 AM
(3,000 Views)
Hallo
Thanks for info!
To you have a ready program for checking an activity on a file.
How could i give a notice for a good answer!
Thanks Werner
(2,984 Views)
Hi Werner,
here's a quick example (made in LV7.1):
Rating messages is easy: in the lower right corner of the message you see 'Rate this message 1-5'-buttons Smiley Wink (You have to be logged in - but you are, as you already wrote a message.)
Message Edited by GerdW on 04-19-2007 01:19 PM
(2,979 Views)
Thanks Gerd
nice day
(2,954 Views)
