"fpsane.cpp" in line 269 appears when trying to save ma VI after the 1st run!
Hi LV-users,
this is a problem some of you may had before. But I still don't know how to solve this problem.
LV crashes when I try to save my VI after the 1st run telling me about the fpsane.cpp-error. It also tells about "INSANE object at FPHP+3EE4 in my VI" and it says
"{sub } (0x10)wave chart" and so on.
I wonder if their is a mistake in a sub VI, maybe because I'm working with references for my wave charts and their histograms which have to be saved if the acquired datapoints are not within tolerance.
I already upgrades my LV-Version to 6.02 and so on...I read about this solution in the Discussion Forum.
I added my VI and Sub VIs using references.
Can anybo
dy give me some advice?
Thanks, Kathrine
(2,599 Views)
Insane error are not due to your programming. There are several good pages on our site that discuss solving these errors. Goto www.ni.com >> support >> advanced search (it is at the bottom--click on the words). This lauches the best way to search our site because under option 2, you can limit your search to resources of interests. Enter insane in the all the words field and search everything. One of the first hits is a knowlegbase that discusses solving this issue.
Jeremy Braden
(2,599 Views)
