08-16-2019 04:03 AM
Dear Community,
I am using LabVIEW Data Connectivity Toolkit to insert long text into an access database field of the type "long text". See attached vi.
The error i get is: invalid precision value.
Only 255 charakters can be written to access. After that i get this error.
I have tried:
- creating an access form for my table to avoid inserting data into the table's raw datasheet.
- changing the text format of the access field into "rich text" rather than "text only".
This did not help.
Do I need to search for a solution working with activeX to communicate with access instead of using the DCT?
Thanks in advance!
08-13-2020 06:31 AM
This topic might be helpful
08-13-2020 06:39 AM
I can't open your VI because I'm using 2017 (save for 2017 and share if you're still stuck after a while), but have you tried using the old data type of "memo"?
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
08-16-2020 07:22 AM
The NI toolkit itself knows only a very limited number of data types. It assumes, that a string is allways a varchar which ist limited to 255 characters. This might be the reason, why you get an error.
Some ideas:
- build your own SQL insert statement and use DB Tools Execute Query from the advanced palette
- or use another toolkit
- create a child class which corrects this issue
- make your own toolkit
