"labview 2009" installation crash
Hello world...
it is annoying that sutch expensive Software often not work like it sounds
(2,726 Views)
You system hang can be due to other process that is running in the back ground.
(2,723 Views)
there was on purpose nothing else running or working at the installation time
...  doesnt matter..  is only an example for one bug
(2,713 Views)
How is it not working like it should?  Is there an error message?
It looks like it is asking for a specific DVD (not sure which one, pPerhaps you could translate the screen to English.)
If you do have that particular DVD in the drive, try taking it out and cleaning it.  A smudge might be preventing it from reading properly.  It is also possible that the DVD is just a bad copy.  Try contacting NI directly.
(2,691 Views)
